1 - 1 of 1 Posts
Testing by feel with fingers, I can shake the rod up and down approx. 1/8 inch. max. I have worked on 2 stroke motorcycle top ends and know that tolerance is no where near that. But based on the top of rod has no bearings. I am assuming the tolerance is a little looser. Drawings on this rod's bottom shows a split sleeve and 33 loose bearings... So I am not familiar with that type of connection either. I have not pulled the bottom apart yet. Waiting on info about the tolerance, to see if needs done.
What should I be looking at and any help with a source for the parts is appreciated. I have seen some on ebay, but not exactly what I needed.
Thanks
Glen:confused:
1 - 1 of 1 Posts
