Need advise! Could I not just remove the axle housing to repair the leaking of oil here around the axle (oil seal & bearing) as it comes out of the housing. Based on the diagram I don't see why that one would need to remove the transmission from under the tractor. Just Unbolting the axle housing from the trans, what holds the axle in? All replies greatly appreciated. :dunno:
Unless there is a snap ring or clip that would need to be removed from the axle before it is pulled out. Looking at the diagram it is possible that the bearing may be pressed on the axle but simply held in by the snap ring that also holds the seal in place. You may not need to remove anything but the snap ring and just pull the axle, seal and bearing assy altogether.
