Hey Ya'll, I am in need for a part number for an older Craftsman LT2000 2006ish vintage. PN 917.275180. Part I'm looking for is the return spring that is wound around the manual blade engagement arm on the dash. It wraps around the arm shaft where it mounts to the bracket assembly and is used to apply pressure on the blade off switch. It has a long arm that pushes down on the engage arm and a shorter arm that anchors onto the assembly bracket.
The spring is broken in the coil. I have looked at many parts diagrams on line and can't find this spring. Even Sears Direct site doesn't show it. Any ideas would be greatly appreciated.
