OK, you are heading in the right direction. You need to pull the carburetor off if you have not already. There will be a some small passages in there, and one or more of them are plugged up. You should get some spray carb cleaner and carefully clean those passages and pass a very small wire (copper speaker wire works good) thru them to clean them out. A bit of carb cleaner in the gas tank will help after you get it running. Good luck, and let us know if this works out for you or you need some more help.
