Hey, new guy here!! Great forum you guys have here, this interwebz thing is awesome isnt it? I have a Craftsman 917.388531 and I think I may have screwed it up. I ran it for about 10 min this Sat, it startred fine and ran fine just as it has for the past 7 years or so but when I went to re-start it it wouldnt start. I noticed that it wasnt even acting like it wanted to start so I knew something was wrong.
I checked the oil and I noticed that it was REALLY low. I probably added more than 1/2 quart before it registered full. I assumed the worst and started looking for ways to confirm if the engine was blown. I bought a spark plug and borrowed someones leak down tester. When I screwed in the tester I didnt notice that the stem was at least twice as long as the spark plug. When I tried to pull the starter it rotated a little then stopped; like it got stuck or someting. I eventually figured out that the leak down tester was screwed in too far. I never got it to read any compression BTW.
I abandoned all of that, put the mower back together and tried to start it with the new spark plug and when I pulled it, it sounded like the muffler had come off. It didnt even act like it was going to start (again) but as the motor was turning over it had that loud open muffler sound.
I cant imagine what I could have done to cause this because the only screws I took off were the ones for the top cover and gas tank.
I read the other post from the guy that had a very similar problem with this exact mower and now that its after the fact I realize that a dirty/clogged carb is a much more likely culprit of my original problem but I digress.
http://www.mylawnmowerforum.com/for...r-craftsman-4-5-hp-will-not-stay-running.html
My basic question is if anyone has actually disassembled one of these engines and is familiar enough with the layout to tell me if there is a way I could have caused that noise to appear by screwing in the leak down tester too far? Sure, I could have cracked the piston or something but I didnt pull hard, just about a 1/4 pull then it stopped. I did have to use a wrench to remove the tester when I originally just screwed it in finger tight. Any help would be greatly appreciated!! Did I mention that this is a great forum
Mike
Mike
