Hi All,
The mower was running just fine and suddenly quit. Checked the fuel, added more, still no run. cleaned the air filter, still no run. Sprayed starter fluid into carb..no run. Check spark..ah ha!!! No spark!!!
So is this a common problem with this model, is there an easy fix? is it a simple matter of replacing the coil unit?
Thanks for your help
Paul
Paul
