Need to replace the dry clutch lining on my mower and does anyone know if it needs to be glued to one of the surfaces?
I made a lining from gasket cork and installed it and it worked fine on testing with the rollers lifted off the ground, but as soon as the weight of the mower was on the ground it seemed to lose power transfer in as much as the rollers wont turn and drive the machine.
I'm assuming the clutch is slipping under load hence the question... do you glue it to one surface??
And if so any recommendations on the glue.
The mower is a Scott Bonnar reel mower which you probably don't know about in USA.
