O rings are a "commodity" item. That is there are many standard sizes available. It is unusual for a manufacturer to use one that isn't one of the standard sizes. You may need an O ring expert, not someone at a parts store to help. Parker and many others make standard O rings. There is also Apple Rubber who makes standard O rings as well a specialty sizes of all types. You will need a micrometer and/or a vernier to measure the O ring that you need. The critical dimension is the inside diameter. The best way to do that is using the conical tool that NAPA stores have and then measure where it goes on the part being sealed. This can be tricky as sometimes O rings are slightly stretched on installation. The other necessary dimension is the crossection. There are difficulties here also. For example, O rings that are listed as being a nominal 1/16" crossection are usually .070" when measured. I'm posting this as, more often than not, the O ring you need is available at NAPA etc. They just don't have the expertise to get you the right one and the equipment manufacturers want you to pay many time what the O ring is worth by claiming that it is unique to their product.
