Hi,
I have been biting my head of getting my stubborn lawn mower (Husqvarna Rider R318) to work again. Hope you can help. It has a B&S Intek 17.5HP engine with less then 200 hours on it.
Problems began when I found the mower to be smoking (blue) making me feel sick after finishing the lawn. Stopped the mower, played with the throttle and when I gave it a blip to full throttle I could clearly see a lot of blue smoke coming out. Then suddenly the engine stalled and I couldn't get it running.
I took the valve cover off and there was A LOT of oil in there almost completely full. Not normal. Also the valves had to much play.
Took the head off and found the head gasket completely ruined (especially the side where valve guides are so this must be how the oil got in the valvecover). Changed the gasket and also cleaned the piston and cilinder/cilinder head (lot of carbon deposits).
Adjusted the valves and checked the clearances twice after a few rotations of the flywheel.
Cleaned the carb (not dirty).
Replaced the sparkplug.
Put it all back together, didn't fire up.
Took me long enough to find the solenoid / plunger in the carb fail not allowing any fuel in the engine. Cleaned that, fired right up but idle wasn't pretty like the timing was off. (put, put, put sound)
Replaced the ignition coil and set the armature air gap.
Idle is now beautiful like new and if I slowly move the control lever I can get it up to mid revs fine. If I push further (or blip from idle to full throttle) it will stumble and stall and can't recover and shut off with a big blow through the intake/airfilter.
When that happens I cannot get it to start again unless I come back the day after of if I empty the float bowl of the carb (Nikki). If I empty the fuelbowl it will start right up and same thing happens all over again.
It just won't go to full throttle. It looks like it is dumping a lot of fuel in the engine when I go to high throttle, overflowing it.
What could be the problem here?
