1 - 15 of 15 Posts
Trying to find some specs on a B&S 10hp engine on this Billy Goat blower so I can find a replacement. 2054320141E1 is the model and type but I'm not really finding anything on the shaft diameter, length and height. Anyone have any ideas on a source for this info or maybe have a replacement model number for it??
2054320141E1
You'll find more info searching for it hyphenated: 205432-0141-E1
Here's the parts manual: ViewerJS
Operator's Manual: https://bsintek.basco.com/BriggsDocumentDisplay/default.aspx?filename=flmsCJX-nfBhU7y
I found these specs:
  • Briggs & Stratton
  • Short Block - Part 696094 NKA 794905
  • Horizontal Shaft
  • Uses Crankshaft 695462
  • 1" Diameter With Keyway Tapped 7/16-20
  • 3-21/32 Measured from Flange mounting face on ball bearing, horizontal crankshaft engines.
  • Mechanical Governor
  • Bearing PTO Side: Ball Bearing
  • Bearing Magneto Side: Ball Bearing
  • Pressure Lubrication
  • Notes: Sleeve Bore
  • Shipping weight = 26 lbs
That manual might come in handy but the engine is seized up for some reason. Do you think that measurement is the length of the shaft?
Also looks like 205432-0141-E1 was superseded by 20S232-0037, then BS20S-0037-F1 and then 19N132-0035-F1.
Have an email into B&S about the replacement engine number but it's been a few days without contact from them. I've been noticing that some of the descriptions for the 19N132-0035-F1 motor says 3-31/64" while others say 3-21/32" for the shaft length. Not sure whats up with that.
I just got this reply so I guess I'm kind of screwed. :(
"The engine that home depot sells would actually not work as a replacement. The shaft diameter and length is not the worry here. It is actually the height from the base of the engine to the center of the crank on your original engine is over an inch shorter.
Briggs unfortunately, does not make a current replacement for the 20 series horizontal engines."
Billy Goat used a spacer plate on the INTEK engine. They also used a 6.5 B&S, 9.0 Subaru, 5.0 and 8.0 Honda on the same chassis but with no spacer. Billy Goat is now telling me 20S232-0108-F1 is the replacement.
I'm not giving up yet!
Discussion Starter · #15 ·
By the way I checked into the Predator 301cc motor and everything lined up but the exhaust stuck out too far. Stuck out by like an inch and a half and there was no way I was going to get something to work with that.
1 - 15 of 15 Posts
