Here I have a Briggs 128T02-0118-B1 on a John Deere a guy brougth me a month ago with a starting problem, the mower is only 2 years old. I got it started by spraying a little starter fluid in the carb and would run on it and start so I basically removed the carb and put in a needle and set and cleaned up the carb and put it back on. It would then start and run for a couple second then on the next pull it would start again wallop down and then back up to operation rpms and steady up. At this point he was happy with it. He used it 2 times and now were back to square one and will only start again with starter fluid sprayed in the carb ? I did a basic compression test and it was only 30. Here i have removed the head to see what we have. The black ridge of carbon on the cylinder wall? What doe's this tell maybe about the problem? Any help would be great! Odviously the engine is not getting proper fuel but also low compression ?//
:dunno:
:dunno:
