OK folks,
Now the fun really begins. I need to ask those that are interested and contemplating painting their project to please remember this:
Learning to paint, handling the paint chemicals and spray painting your projects is like setting off Dynamite....It's FUN AS H***
but extremely dangerous! And like explosives, if you use caution, handle it carefully and protect yourself you're going to enjoy your new found passion.
I urge you to read the following warnings authored by a CA insurance institute. I explains some of the hazards related to spray painting and using personal protective equipment (PPE)!
"Spray Painting Safety:
Spray painting is a common and effective way to protect and beautify parts, products, vehicles, and buildings. Spray painting allows coverage of large areas with even coats of primer, paint, sealers, and other coatings. However, workers in spray painting operations need to recognize and guard against the hazard associated with spray painting processes.
Many paints, coatings, catalysts, sealers, hardeners, and solvents contain hazardous chemicals. Exposure to chemicals can occur during mixing of the coating, spraying the material, and grinding or sanding it. Even some surface preparation and cleanup solvents can pose a hazard, if not handled properly. As such, workers should avoid using solvents for cleaning paint from hands or skin. They should use water-based cleansers that are meant for personal cleanup.
Hazardous chemicals in coatings and solvents can enter the body several ways. Workers can inhale chemical vapors from spraying, absorb the chemical by skin contact or inject the chemical with high pressure spray painting equipment. Symptoms of overexposure to hazardous chemicals include nausea, rashes, and long term illnesses like asthma, lung cancer, and sensitization (becoming severely allergic to the paint). Before work begins, spray painters should read the Material Safety Data Sheet (MSDS) of the chemical they'll be using then wear the appropriate personal protective equipment such as safety glasses, a respirator (if medically qualified, properly fit-tested, and trained), gloves or coveralls to protect themselves against its hazards.
As proper ventilation is important when working with paint coatings, a spray booth is an excellent way to remove spray paint vapors and debris from a worker's breathing zone. Many coatings contain flammable substances that are aerosolized when sprayed through powered equipment and without proper ventilation, such as in a spray booth, these vapors can build up and create an explosion and fire danger. But to provide maximum protection, the spray booth must be properly maintained, including regular cleaning of filters and overspray. And to prevent sparking a flammable substance, smoking and other sources of flame near spray painting operations should be prohibited and tools should be properly rated and grounded for work in a spray painting area.
So, it's pretty obvious from their warnings that using common sense and learning to paint needs rules of engagement. Don't let this scare you off though. Like any fun and interesting profession where one can have fun and, in many instances, grow from a hobby to where they supplement their income...you just need to be careful.
Thanks for reading!
Thanks for reading!
