I have B & S Engine,
Engine Model: 446777
Engine Type: 0244
Engine Code: 040630YG
Horsepower: 26
Model Name: Extended Life Series (ELS)
This engine is a vertical shaft engine and I am thinking of tearing it down to look at piston and rings. If I can repair this engine I would like to find a tractor to put it on. It has a 1 1/4" vertical shaft, not the usual 1" shaft that I see on most lawnmowers.
Does anyone know how to find out which lawn mowers used this engine? Is it possible to contact B&S and give them the model no., etc. and they can tell me which manufacturer may have purchased this model or any manufacturer that used a similar engine with the 1 1/4" shaft?
I am mostly concerned that if I pick a used tractor, that I can use the same pulley system to run deck or drive belt if any.
Thanks, MR
Engine Type: 0244
Horsepower: 26
Thanks, MR
