Good morning all,
The issue is that the carb is leaking, and it appears that the gasket/o-ring has become distorted.
I have tried everywhere to find a replacement, without luck. I have measured the diameter of the carb sump , it appears to be approx. 45mm, the o-ring is a flat type about 1.2mm?
The Carb doesn’t have makers name or logo, can only see 8K stamped on it. The engine I don’t know.
I have attached a couple of photos which may help identify what it is.
If the o-ring is unobtainable, what a waste of a great mower which starts first time and does a great job. any suggestions if unobtainable, is there any "stuff" I could use to "perfect" the seal?
