I have a clutch that needs adjustment......again. How s this done, iknow about the feeler gauges and .0018 gap ..adjusted by the three nut on the clutch. But where i get lost is which place do you slide the gauge in .Between the pulley and the clutch . thru the nuts ?Which place are they slid in.Last question on this thread. If i have to pull the clutch.does this require taking the bolt out and the clutch --then just..".drops off"Does the deck require removal? .My grass is growing so fast i cut and acre every 3rd day.
Thank you for reading this i truly appreciate getting this switch...clutch thing taken care of bob s
I believe it is between pulley and clutch Bob!
