I am a new member and this is my first post although I have been getting lots of good info here for the past few months. I got bit by the Lawn Boy bug a few months ago, and I am having lots of fun with the little green monsters.
I need some help with a 8243AE. I aquired it along with two others a few weeks ago from an estate. The starter and battery were shot, so I added a recoil and converted it over to pull start. The problem is that is is very hard to start. This model has a Walbro carb without a primer -handle mounted choke only. I can pull all day and it won't fire. If I give it a shot of starting fluid it starts right and runs fairly well. I have pulled the carb apart and cleaned it. I have played around with the altitude adjustment screw with no imporvement. The lower crank seal is dry, so I don't think that is the problem. It does surge a little at low throttle, so it may be a bit lean, but there are no adjustments other than rejetting?
I have another 8243 pull start, and this one has a Wlabro carb with a primer. It starts easliy. Is my problem the lack of a primer because it was an electric start model, or am I missing something here? Any advice would be appreciated.
