1 - 12 of 12 Posts
Hello all,
I am a high school agriculture teacher in Western NY. A student in my Small Engines class has just rebuilt a 6.5 HP Briggs and Stratton 124T02-0464-E1 vertical shaft mower engine. Prior to me bringing this in to school, it was given to me. I messed around all summer trying to get it to run right. No matter what I did to the carburetor, it would not draw fuel on its own. If primed, it would run as long as you kept spraying gas down the throat of the carb. I figured the original carburetor was damaged beyond repair. Fast forward a few months, the engine received a honing, new rings, valve lap, all new seals and gaskets and a new intake pipe. We put on a carburetor from a never been run engine that we had on our parts shelf. It is doing the exact same thing. We have tried a few different new carburetors. Spray gas down the carb, it runs until it runs out. It is getting good fresh fuel. We are at a complete loss. Any suggestions would be greatly appreciated. Thanks for any help that you can offer.
Forrest
Did you check the fuel lines upstream of the carb for restrictions or gunk buildup? Are all of the intake components secured tightly? (to prevent vacuum leak)
I know this may sound dumb, but maybe it's stopped up before the carb. I have seen bugs clog the nipple on the tank of stuff that I had already confirmed clear. I presume it was in the gas can...
Sounds like all tech schools rebuild the same stuff. When I was a sophomore, we started off the year with the 12 cubic inch Briggs flatheads as well. Still have plenty of brand new never run engines on our shelves. I'll give it a crack and say a clogged fuel line or dirty gas tank.
If you're sure its still getting good, fresh fuel , after trying few "new" carbs....and will run continuously if constantly sprayed with fuel...then I still think it has misaligned camshaft timing from the rebuilds...causing very poor suction, but just enuf compression to run on primes..? Or a totally mismatched head gasket..restrictive..
Same problem with mine
I have a B and S mower. Pulled carb to clean, now after priming it will start but dies after fuel in throat has been burned. Sometimes it will keep running but at reduced RPM, around 2000. I am thinking pull carb back off and clean again. Any other ideas? It has a non adjustable carb on it
:welcome: to MLF Jack. Could you post the engine numbers so we know what type of carb you have?
1 - 12 of 12 Posts
