· Founding Administrator
If you go to the Toro.com (or lawnboy.com) you should be able to put in your model number under the "Look up parts" option. Will tell you the general specs for the engine. 105 should be a very good compression ratio.
I went all through the manuel and no where does it say compression specifications.
any other suggestions ---please
