Just picked up an early 90's 14SZ for a whopping $12 at auction. No history on it, but I figured it was worth the gamble. First thing I did was dumped the little bit of fuel that was in it and removed the carb to clean it. No sediment in bowl and jets appeared very clear - it seemed like someone might have had this apart semi-recently but I blew them all out with carb cleaner any way.
Went ahead and put a little fresh fuel in it and tried to start it. No luck. Tried spraying a little ether in the carb and ever so briefly it would run and then immediately die. Repeated that a couple times with same results. It really only runs for the shortest amount of time - less than I've experienced before when I run an engine on just a shot of ether.
Checked compression and I'm getting maybe 45 PSI. That would only be okay if there's a de-compression valve on this thing. Is there? If not, I figure I need to check valve lash next.
For the two adjustment screws on the carb, I'm assuming 1.5 turns back from fully screwed down is a good starting point, yes?
