Air compress or will not get to top pressure - Lawn Mower Forums : Lawnmower Reviews, Repair, Pricing and Discussion Forum
The Tool Box A place to share information or tips on tools of the trade that we have made, adapted or just use on a regular basis that would apply to Engine Repair or maintenance on Walk Behinds, GTs or LTs.
 2Likes
  • 2 Post By keakar
post #1 of 9 (permalink) Old 08-24-2018, 06:07 AM Thread Starter
Hi all,
I have a little All-Power Model AC 1508-HM air compressor that I use to pump up tires etc. It will not get up to top pressure. It will just run and run until I suppose that the motor would burn out. I have already taken it apart, checked and replaced the gaskets, but that did not help. What else can I check?
bluegirl64 is offline
post #2 of 9 (permalink) Old 08-24-2018, 07:43 AM
Ericjr16's Avatar
Garage
Do you have any leaks? Might be bad seals on compressor itself.
John Deere LX172 bagger
John Deere 180 yard tug
1997 John Deere 345
1967 Sears Suburban SS10
1971 Bolens 1256
Craftsman 9HP snow blower
Honda HRB215SDA mower
Change is the normal with my tractor list!
John 3:16 Psalm 28:7 1 Corinthians 15:57
"Complain and remain, praise and be raised! "
Ericjr16 is online now
post #3 of 9 (permalink) Old 08-24-2018, 10:08 AM
keakar's Avatar
at some point those little compressors just wear out and dont have the compression to pump any more, most of them that arent commercial grade dont have rings, its just the piston sliding in the cylinder and when it wears down its just time to toss it out and replace it
wh55 and Ericjr16 like this.
keakar is offline
post #4 of 9 (permalink) Old 08-24-2018, 02:28 PM Thread Starter
I took apart the piston and the rings & cylinder are both clean and smooth. I will take apart & clean more connections next.
post #5 of 9 (permalink) Old 08-24-2018, 08:50 PM
motorhead12's Avatar
Like Keaker says, these compressors have a limited service life. They typically have a silicone sealing ring with some grease for lubrication, so they don't last all that long. You still might just have leak though, so definitely check any connection points!
motorhead12 is offline
post #6 of 9 (permalink) Old 08-24-2018, 09:13 PM Thread Starter
I checked most of the seals so far and I am trying to discern whether the hissing noise I hear at the from of the unit is from the fan or from something under the electrics. There is a small copper hose attached to the unit under the on/off switch. How does the air supply travel under there? Any guesses?
post #7 of 9 (permalink) Old 08-25-2018, 01:12 AM
Mark / Ohio's Avatar
Garage
That is probably the line going to your pressure switch. That is what turns it off and on based on tank pressure. Possible the switch itself could be leaky.
Mark - 2002 John Deere LT150H
Mark / Ohio is online now
post #8 of 9 (permalink) Old 08-27-2018, 12:27 PM
Kiss4aFrog's Avatar
To me there is a big difference between the noise a fan might make and the hiss of an air leak. I'm going to guess you are hearing an air leak and you might want to try and put a little bit of dish soap with water in a spray bottle and try seeing where it bubbles.
You obviously want to be careful of the electrical connection. Just mist it on.
The advice is free, you get what you pay for
Sears 18hp 46"
Toro WH 265-6 w/38"
JD 160 w/38"
Kiss4aFrog is offline
post #9 of 9 (permalink) Old 08-28-2018, 08:40 AM
If you have lots of free time these can be patched up. Sometimes the parts are available. If your time is valuable just throw it away.
rentalbarn is offline
