26hp Kohler motor flooding problem - Lawn Mower Forums : Lawnmower Reviews, Repair, Pricing and Discussion Forum
 2Likes
  • 2 Post By Robin
post #1 of 4 (permalink) Old 10-21-2020, 11:10 AM Thread Starter
mikeboggess's Avatar
LG2554 54" cut rider. Flooding occurs unexpectedly. When I fill the tank (not running) the fuel level drops perceptibly. Then staring sequence is to have the throttle at 1/2 position and key start 4-5 times, then the motor starts stumbling with lots of black smoke then smooths out. When I fill the tank (running) the fuel level drops not as bad, but the motor bogs down and continues running. Is this a simple carb. adjustment?
mikeboggess is offline
post #2 of 4 (permalink) Old 10-21-2020, 06:09 PM
Yes
Not so much adjustment as a cleaning
Your float is not cutting the fuel off so it flows right through the carb & into the sump
Check the oil level it will probably be over full
bertsmobile is online now
post #3 of 4 (permalink) Old 10-26-2020, 05:45 AM
If your oil is over full, you should change it as well.
BlueHonda is online now
post #4 of 4 (permalink) Old 10-28-2020, 10:00 AM
While disassembling the carb and fixing the float [shut off] mechanism IS the proper fix, I always also like to add a fuel shut off valve in the supply line from the fuel tank. Sooner or later many fuel shuts fail. It can happen just from debris in the fuel or even corrosion of the needle valve. You don't want to risk fuel leaking, especially if the mower is stored in a garage connected to your home.
bertsmobile and Scrubcadet10 like this.
Robin is offline
