Oil Lock a reality? - Lawn Mower Forums : Lawnmower Reviews, Repair, Pricing and Discussion Forum
 9Likes
  • 1 Post By bwdbrn1
  • 3 Post By keakar
  • 2 Post By motorhead12
  • 1 Post By Joe Kuhn
  • 1 Post By bwdbrn1
  • 1 Post By motorhead12
post #1 of 9 (permalink) Old 05-18-2020, 09:48 PM Thread Starter
Oil Lock a reality?
Can your engine seize up from too much oil?
While walking the dog, I found a Troy-Built on the curb and talked to the owner who said the engine was seized. I lifted the front end and moved the blade about 3 inches with no problem. Seemed like it wasn't seized to me. Owner had already purchased a new one...
It ended up at my house where I changed the oil that was about an inch overfull and black. Dumped the gas, put 30 weight back in, added fresh fuel and it started first pull. (Also added handle bolts that had been snitched, a replacement cable for the kill lever and cleaned the plug on my wire wheel.) It smoked heavily for about 5 minutes, but then it cleared up and mowed fine.
Son suggested it might have been seized from too much oil. I supposed if oil gets up into the upper part of the engine, that could happen. The smoking was sure evidence that oil had gotten where it shouldn't have been.
Ever hear of an engine seized from too much oil?
Joe Kuhn is offline
post #2 of 9 (permalink) Old 05-19-2020, 06:10 AM
bwdbrn1's Avatar
Hmmm...did you find oil in the air cleaner? The pressure of the piston and all that other stuff whirling around in there has to be relieved somewhere and that’s the job of the breather. Or at least that’s my understanding. I suppose if you fill the crankcase up until nothing more will go in then give the rope a mighty tug nothing is going to move until it can find a place to squeeze out the excess.
Joe Kuhn likes this.
bwdbrn1 is offline
post #3 of 9 (permalink) Old 05-19-2020, 07:26 AM Thread Starter
The air cleaner was brand new, so I'm guessing the previous owner tried replacing that as an attempt to fix the problem. And you're right, air is way more compressible than a liquid (oil), so I'm supposing that's what caused this owner to scrap it to the curb.
Joe Kuhn is offline
post #4 of 9 (permalink) Old 05-19-2020, 10:30 AM
keakar's Avatar
yes, its called hydro locking, liquid cant be compressed, only gasses can.
most often its from carbs leaking gas into engines but it happens with oil a well.
simple solution is remove plug and spin it over, any liquid in cylinders will blow right out spraying everywhere, so dont stand in front of the plug hole when you do it lol.
from what you describe, it sounds like the carb leaked and filled the cylinder with gas hydro locking it. gas eventually seeps passed the rings and into the crank case and thats why the oil level was high. see it all the time and it puts out a ton of white smoke when you start them up after.
you will need to clean the carb and put in a new float needle or just replace the carb or it will happen again
motorhead12, laabk2 and Joe Kuhn like this.
keakar is online now
post #5 of 9 (permalink) Old 05-19-2020, 03:40 PM
motorhead12's Avatar
Yep, bad needle/seat will leak over time and hydro lock an engine. Usually happens when people let it sit with gas all winter and the whole tank drains into the sump gradually. The acid test is sniffing the oil to see if it is super diluted with gas.
keakar and Joe Kuhn like this.
motorhead12 is offline
post #6 of 9 (permalink) Old 05-19-2020, 03:59 PM Thread Starter
Oil was not diluted with gas as it was black and thick and I didn't notice a smell. I've seen that before and would have noticed. Definitely a possibility though, but not with this one. I think the guy dumped a whole bottle in it instead of a half.
Machine went to neighbor, so I can track any further issues.
Thanks
keakar likes this.
Joe Kuhn is offline
post #7 of 9 (permalink) Old 05-19-2020, 04:08 PM
bwdbrn1's Avatar
Sounds like a winning deal all around.
bwdbrn1 is offline
post #8 of 9 (permalink) Old 05-20-2020, 07:25 PM
Sounds like you had a good result!
post #9 of 9 (permalink) Old 05-21-2020, 07:48 AM Thread Starter
Checked on the leaking-fuel-into-oil concept and the oil level is right where I left it 2 days prior. Excellent possibility, but ruled out. So I guess I'm left with owner overfilling the oil as a cause. Will see how it mows when new owner first uses it.
Thanks fellas.
Joe Kuhn is offline
