Kawasaki FC290V only runs with starter fluid - Lawn Mower Forums : Lawnmower Reviews, Repair, Pricing and Discussion Forum
 1Likes
  • 1 Post By Josh411
post #1 of 7 (permalink) Old 08-29-2020, 03:59 PM Thread Starter
I'm working on my John Deere RX73. After finally getting the no spark figured out. I put everything back together. Had some trouble getting it started but after some adjustments on the carb, it fired up and ran fine except for burning oil. Drained it and refilled to the right amount and that straightened out.
I was testing the transmission to make sure the mower would drive properly. After doing so I out it back into neutral. Then the engine started to big down a couple times before eventually shutting off completely. Now I can't get it started again unless I throw some carb cleaner or starter fluid in the intake. I thought maybe the float or needle valve was bad so I just put on a whole new carb. Still cant get it started. I'm wondering if maybe the engine flooded. Any thoughts?
Josh411 is offline
post #2 of 7 (permalink) Old 08-29-2020, 05:14 PM
keakar's Avatar
sure sounds like it flooded out on you from a bad float needle, to check this just pull the dip stick and if it smells like gas, then it flooded and you know you need to change oil and filter again and replace the carburetor
this is why i dont even bother trying to save a carb unless the engine is running fine and just slowly floods after sitting a while or overnight, then in those cases i will try a carb kit and put a new float seat in to save a few dollars and that usually sorts things out
but the reality is, when you can buy a new carb for $25 vs a rebuild kit for $12 so its not worth your labor time fooling around with trying to save it so its actually cheaper to just replace the carb rather then try to fix an old carb
keakar is offline
post #3 of 7 (permalink) Old 08-29-2020, 05:59 PM Thread Starter
Alright I'll have to pick up some more oil and give that a try. Already replaced the carb so hopefully this is all that's needed. Thanks for the advice. I'll update after I try it.
keakar likes this.
Josh411 is offline
post #4 of 7 (permalink) Old 09-01-2020, 08:55 PM
I don't think it's flooding...if it needs carb cleaner or start fluid, and it starts..assume runs...! I had owned that model many years ago...recall it had a fuel pump? Or perhaps gas line is collapsing, restrictive...or clogged filter...?
post #5 of 7 (permalink) Old 09-02-2020, 01:48 AM
Start the engine with the carb cleaner
As it dies give it another SMALL shot
If you can keep the engine running for a minute or so like this then you have a fuel supply problem.
If it has a solenoid on the carb that would by my next port of call.
Check tha it retracts very quickly & fully when the ignition is turned on.
bertsmobile is online now
post #6 of 7 (permalink) Old 09-04-2020, 05:00 PM Thread Starter
This model doesnt have a solenoid or a fuel pump. It's gravity fed and a recoil. I drained the oil and put new in. It didn't turn over at first so I used starter fluid and it kicked on and ran until I turned in off. I let it sit for a few minutes and tried again and it worked. The third time however it didn't. I know I'm getting low on fuel in the tank but the float bowl should be full as I can see fuel in the filter and I can drain fuel out of the bowl. Now it won't start even with starter fluid. All I get is a puff of black smoke out of the intake.
Josh411 is offline
post #7 of 7 (permalink) Old 09-08-2020, 09:36 PM
Your original thought was flooding...but you put on a new carb..Right? And you say you need to spray with carb cleaner to get it started...That step will NOT start a flooded engine...Yet, the black smoke you saw is an indication of flooding....Two different situations here..!
