Briggs and Stratton Charging Issue - Lawn Mower Forums : Lawnmower Reviews, Repair, Pricing and Discussion Forum
 3Likes
post #1 of 19 (permalink) Old 06-28-2020, 07:49 PM Thread Starter
Hello all,
I have a question regarding the charging system of my 20hp engine. It has a 2 wire system, when I plug in my Fluke meter to the two wires it produces 24.3 volts. When I test for ac voltage its around 14 volts. But the battery is only 12.6V D/C and slowly dying when in use.
There is not a voltage regulator on this mower, and its a replacement for the old Kohler 19hp.
I just bought this lt1045 used a couple weeks ago and the guy failed to mention this issue. So I purchased a new battery per his advise, no luck.
What could possibly cause this engine to not charge my battery? I thought maybe a bad stator but it seems ok. Maybe I missed a quick test to do.
Stamped engine number is 31P977
Any and all help, advice and criticism is appreciated.
Thanks
Sean
Duster73 is offline
post #2 of 19 (permalink) Old 06-29-2020, 01:55 AM
keakar's Avatar
Quote:
Originally Posted by Duster73 View Post
Hello all,
Thanks
Sean
thats because one puts out ac volts to run the headlights and accessories and the other with the large diode one it puts out the dc volts for the charging system
touch one lead to ground and the red to each wire and both individually should read above 12v
odds are the 12v dc side is fried
keakar is offline
The Following User Says Thank You to keakar For This Useful Post:
Duster73 (06-29-2020)
post #3 of 19 (permalink) Old 06-29-2020, 06:39 PM Thread Starter
So I tested the wire with the diode. It is putting between 14.3 and 15 volts DC. The strange thing is that I believe I tested this last week and wasn't getting a reading at all, now I am.
Duster73 is offline
post #4 of 19 (permalink) Old 06-30-2020, 03:42 PM
motorhead12's Avatar
Check for a loose connection/damaged wiring/harness. That's the easiest intermittent failure mode to trace.
motorhead12 is offline
The Following User Says Thank You to motorhead12 For This Useful Post:
Austen (07-01-2020)
post #5 of 19 (permalink) Old 07-01-2020, 01:24 AM
keakar's Avatar
could have just not been making a connection or the wire from the plug to the battery side of the starter solenoid is bad. thats were most charging wires are connected to.
but as motorhead12 suggests see if moving the wire around shows intermittent power, if it does you can trace that break in the wire back using ohm meter on the wire and see if its something you can fix or if you need to replace the alternator ring assembly
keakar is offline
post #6 of 19 (permalink) Old 07-03-2020, 02:38 PM Thread Starter
So I just retested the DC wire off the stator and now its putting out 22 volts. This seems extremely high, but the battery still reads 12.7V.
Do you guys think I might have 2 separate issues? Bad stator and an open in the wire to the battery?
Duster73 is offline
post #7 of 19 (permalink) Old 07-05-2020, 08:25 PM
Do you have an auto ranging meter or one with a hard wired switch for either AC or DC volts.
The DC out[ut from the single diode type stator is pulsed from 0 to 13 & back to 0.
A lot of auto meters will see this as AC so give you an AC reading.
IF the diode is buggered you will get an AC reading of 22 V but that is only 11 V DC which is not enough to charge the battery.
I tossed my nice new expensive multimeter for an old one because I kept on having the same problems with it switching DC to AC without me noticing.
Check the battery posts for AC between them
If you get an AC reading then the diode is toast.
Again if you put a lot of meters on an AC line while they are set to DC you will get a wrong reading ie, 14V DC when it is actually 28 V AC
Mark / Ohio likes this.
bertsmobile is online now
The Following User Says Thank You to bertsmobile For This Useful Post:
Duster73 (09-16-2020)
post #8 of 19 (permalink) Old 07-07-2020, 08:47 PM Thread Starter
I didnt even think about the meter switching between a/c and d/c. Very good thought. I will check this out and get back with the results. Thanks
Duster73 is offline
post #9 of 19 (permalink) Old 09-01-2020, 10:05 PM Thread Starter
Recently had our first baby after this post was made and what a life changer. Now I can get back to fixing my mower.
So I checked the DC voltage after the diode, its still 22V at the bullet terminal inside the connector of the stator when separate from the harness.. But when I check the top of the connector closest to the diode/stator it's 17V. Pretty strange considering its slightly closer to the diode then the bullet terminal.
Second, once I plug in the other side of the body harness to the stator connector, it is constant 12.3V. Same as the battery, full throttle or not. I separate the two connectors and the harness side is still 12.3V, the stator side is 22V.
Very confusing, any ideas??
Thanks
File Type: jpg 20200901_184056_capture_1599008656682.jpg (789.0 KB, 2 views)
Duster73 is offline
post #10 of 19 (permalink) Old 09-02-2020, 02:53 AM
Rather than write pages of detailed instructions and then the theory behing the results, go download the Briggs "Repower Guide"
It is all over the web and has detailed instructions as how & where to test the charging system
