carb jetting question for B&S 2 cylinder engine - Lawn Mower Forums : Lawnmower Reviews, Repair, Pricing and Discussion Forum
 2Likes
  • 2 Post By keakar
post #1 of 4 (permalink) Old 05-19-2020, 01:12 AM Thread Starter
keakar's Avatar
i have a Briggs & Stratton 44N877-0003-G1 with the auto choke, so its not the 2 barrel carb, its the single barrel carb in it
i realized the main jet has fallen out so i used a spare from those standard carb rebuild kits for the 14-20hp single cylinder inteks
well the engine runs sorta as it should but clearly the jet is too small since at full throttle its only running like 1/4-1/3rd speed at best
i found another jet i dont know whats its from but it must have been a 20-21 hp since you can see the hole is noticeably larger so i'll try that in it when i get a chance.
my question is, if anyone knows, since i have at least 2 different size jets, how many different standard sized jets are there?
im assuming that the small jet size was for 14-17 hp and the larger jet size would be for the 18-21 hp but would that be enough flow for a twin cylinder engine?
keakar is online now
post #2 of 4 (permalink) Old 05-20-2020, 12:31 AM Thread Starter
keakar's Avatar
oh well, i was hoping someone knew something
it is a strange request after all
there are just no carburetor kits for this engine and im not keen on buying a $25 main jet for the carb and a new carb costs $200
i'll try the jet i found that has a bigger hole and see what happens
if thats not enough then i'll break out the drill bits and make my own jet
post #3 of 4 (permalink) Old 05-22-2020, 01:02 PM Thread Starter
keakar's Avatar
ok the jets i had from the carb rebuild kits were small and the one i used in the carb was a little larger then those but the one i found with the bigger hole was just a tad bigger then the other one so i used that and it seems to run pretty good now.
but i dont think it still has full throttle. it just seems too quiet and rpms are lower then i would expect but its hard to tell and it seems good and strong and no longer struggles when blades are engaged like with the medium sized jet.
if i had to guess i would say it maybe runs about 2/3rds rpms that i would expect it to at the fast throttle setting now. but then its fairly new and being a twin maybe it is just a very quiet engine
im gonna call it fixed at this point and if she struggles in tall grass then i will bit the bullet and just buy the $25 jet for it
end result working on this mower is
- the governor arm needed replacing
- someone took the carb apart and lost the main jet and put it back together like that blowing up the in the process
- they also lost the bolts for the intake manifold so i had to dig through my spare bolts bucket to find the right length ones for it
- the cooling fan was busted up because the cover was loose with half the bolts missing on it so i had to dig through my spare bolts bucket to find them
all this on a 3yr old lawnmower but its all fixed the right way now, with the possible exception of the questionable jet issue
Mark / Ohio and Grunt like this.
post #4 of 4 (permalink) Old 05-26-2020, 03:18 PM Thread Starter
keakar's Avatar
these should say:
- someone took the carb apart and lost the main jet and put it back together like that blowing up the governor in the process
- they also lost the bolts for the intake manifold and used the too short valve cover bolts for it so i had to dig through my spare bolts bucket to find the right length ones for it
