JD STX38 won’t start - Lawn Mower Forums : Lawnmower Reviews, Repair, Pricing and Discussion Forum
 1Likes
  • 1 Post By Tom Mullins
post #1 of 5 (permalink) Old 07-06-2019, 08:31 PM Thread Starter
I recently bought a John Deere STX38 black deck with a Kohler Command CV125S. The guy said it ran fine for the past three years he’s had it, but wouldn’t start this season. After about ten seconds of cranking with the choke on, the mower will briefly fire, but die within 2-3 seconds. I have replaced all fuel lines, fuel filter, fuel shut off valve, cleaned the tank and fuel cap vent, and and ignition module. I cleaned the carb, but have not rebuilt it. I tried resetting the carb adjustments, but it didn’t help anything. Other than this issue, the mower is in excellent condition. Thanks for any help!
Tom Mullins is offline
post #2 of 5 (permalink) Old 07-07-2019, 02:40 PM
keakar's Avatar
first i recommend you replace the fuel line from tank to carb, if they ever used ethanol gas it could be swollen shut on the insides but if the mower is over 5 years old is a good idea to replace it no matter what as they dry out after 5 yrs
after that buy a new carb for it on ebay, they are only like $15, bolt it on and you are good to go
keakar is offline
The Following User Says Thank You to keakar For This Useful Post:
Ericjr16 (07-10-2019)
post #3 of 5 (permalink) Old 07-07-2019, 04:08 PM Thread Starter
I’ve already replaced everything from the fuel tank up to the carb. I know I’m getting spark, as it will fire with starting fluid. I guess I’ll get a new carb, and see what that does.
keakar likes this.
post #4 of 5 (permalink) Old 07-07-2019, 06:37 PM
keakar's Avatar
ya those carbs can be a PITA to get cleaned and a new carb is only like $5 more then buying a rebuild kit for them
buy a new one, bolt it on, and then you can relax and go drink a beer
i think this one fits yours https://www.ebay.com/itm/Carburetor-...MAAOSw89lcoct0
keakar is offline
post #5 of 5 (permalink) Old 07-09-2019, 11:23 PM
It's possible you do not have a fuel problem...You may have an engine that had a sudden "stop" and now has a slightly off time ignition with a partially sheered flywheel key...You may want to do a check..remove shroud, and flywheel nut..carefully inspect the key...If in doubt...put in a new one...and fully tighten the flywheel...Only other reason I can think of, is your choke butterfly is not fully closing...but based on the work you already did, I'm sure you checked that...Good Luck..
