Husqvarna yth22v46 carb riding mower - Lawn Mower Forums : Lawnmower Reviews, Repair, Pricing and Discussion Forum
Lawn Mower Main Forum This is the main MyLawnMower Forum discussion forum. Here you can discuss the latest lawnmowers, and other lawn care machinery.
 4Likes
  • 1 Post By Carolynski
  • 1 Post By jtclays
post #1 of 10 (permalink) Old 07-04-2018, 10:13 AM Thread Starter
I’ve got a Husqvarna yth22v46 with a Briggs 22hp that I picked up for a friend from a shop that was taking forever to fix it. Unfortunately everything was still apart when I got it.
Can anyone take a couple pics of their carb to show me how the linkage goes on the carburetor? I don’t think I have the little springs right. Thanks in advance!
File Type: jpeg 69466822-6581-4EFC-B96A-9E112435CD99_1530718834729.jpeg (1.03 MB, 8 views)
File Type: jpeg F1FD675F-1353-4EBA-B028-C74A83A3C4CD_1530718948787.jpeg (2.29 MB, 6 views)
File Type: jpeg CBFD70CC-C758-4125-A541-77BFF051BE61_1530719003542.jpeg (2.44 MB, 7 views)
Carolynski is offline
post #2 of 10 (permalink) Old 07-04-2018, 12:17 PM
keakar's Avatar
well the plastic thingy on the choke rod with the red dot gets turned 90 degrees clockwise and the rod snaps into that slot in the plastic holder.
on the carbs i worked on, the throttle rod on the right hand side didnt have anything crimped onto it, that appears to be some home made "rigging" for something, but i cant imagine what for. this is what it looks like "unrigged" https://www.ebay.com/itm/Briggs-Stra...item3d69cb08b7
it just goes straight up and hooks onto the carb throttle butterfly shaft but it needs to be connected with the carb off the manifold or its near impossible to get it on, then with carbs mounted to manifolds, the hook part just hooks onto the spot its hooked to in your picture and then you can align and bolt the manifolds onto the engine.
on the few i worked on none had the small "helper" springs on the throttle link rods like you see on single cylinder engines
also, i cant really tell what im looking at in the first picture with that threaded bolt sticking out, but "if" that is the back side of the carburetor, then it appears the air intake isnt mounted to the carb and that must be done before the intake manifold is installed on the engine
keakar is offline
post #3 of 10 (permalink) Old 07-04-2018, 03:16 PM Thread Starter
Thanks Keakar I think I got the carb figured out and it rode great several times but now it won’t start lol all I did was test cut the grass pull it in the driveway and blow the grass off. Now it won’t start humph
keakar likes this.
post #4 of 10 (permalink) Old 07-04-2018, 03:21 PM
motorhead12's Avatar
Is it still getting gas? Check the plugs for wetness and try to get it to fire with carb cleaner spray.
This We'll Defend
motorhead12 is offline
post #5 of 10 (permalink) Old 07-04-2018, 03:22 PM
Shut the PTO off! Been there, done that too many timesDepending on where you are, it could be a bit of vapor lock too. Try loosening the gas cap. It's been in 90's and humid here for a few days with not a breath of wind. Taking a nice cool tractor out of the garage and running around in this heat can develop some funky condensation.
keakar likes this.
jtclays is offline
post #6 of 10 (permalink) Old 07-04-2018, 04:15 PM
keakar's Avatar
added to the above mentions, make sure the plug hasnt come loose to the fuel solenoid
also check to see if the fuel pump hose to the valve cover is in good shape and that the fuel pump hasnt busted the diaphragm and stopped pumping fuel
keakar is offline
post #7 of 10 (permalink) Old 07-04-2018, 08:23 PM Thread Starter
Thanks y’all everything looks good I put a new fuel filter and fuel pump works solenoid is good. Has all clean gas put new plugs in it. Still wouldn’t start so I took apart the carb again and it ran for a few minutes then wouldnt start again.
The original problem was the carb was stuck and flooded into the engine and mix gas with the oil and smoked. A shop had it and told my friend the motor was shot and needed a new mower but it’s only two years old and they wanted $450 just to put it back together if you can believe that. It was just the fuel in the oil that made it smoke and that’s gone now that I’ve changed the oil and filter.
I went ahead and ordered a new carb for it. Hopefully that will do the trick. For $165 for a carb it better lol
keakar likes this.
post #8 of 10 (permalink) Old 07-05-2018, 10:12 PM
keakar's Avatar
Quote:
Originally Posted by Carolynski View Post
Thanks yíall everything looks good I put a new fuel filter and fuel pump works solenoid is good. Has all clean gas put new plugs in it. Still wouldnít start so I took apart the carb again and it ran for a few minutes then wouldnt start again.
The original problem was the carb was stuck and flooded into the engine and mix gas with the oil and smoked. A shop had it and told my friend the motor was shot and needed a new mower but itís only two years old and they wanted $450 just to put it back together if you can believe that. It was just the fuel in the oil that made it smoke and thatís gone now that Iíve changed the oil and filter.
holy cow man you got robbed, they only cost $40 i buy them all the time https://www.ebay.com/itm/Carburetor-...72.m2749.l2649
any way most likely just has trash inside the passages of that carb that flaked off the sides when it started running and clogged something up. i bet if you gave it a goods 24 hr soak in some chem dip carb cleaner can it would run perfect after that.
keakar is offline
post #9 of 10 (permalink) Old 07-05-2018, 11:51 PM Thread Starter
This one is a single barrel carb. It’s a 2016 mower and there isn’t an aftermarket carb for it yet. Briggs part number 595216 had to buy oem
keakar likes this.
post #10 of 10 (permalink) Old 07-06-2018, 01:43 PM
keakar's Avatar
This one is a single barrel carb. Itís a 2016 mower and there isnít an aftermarket carb for it yet. Briggs part number 595216 had to buy oem
darn ok ya the ones i get are 2 barrel, didnt realize the aftermarket single barrels arent available, thats no fun to drop that much coin but if you need it you need it
keakar is offline
