Wet Spot Drainage! - Lawn Mower Forums : Lawnmower Reviews, Repair, Pricing and Discussion Forum
Lawn Care and Landscaping Forum Discussion regarding your lawn care and landscaping. Post pictures of your landscaping plans, or your completed project. Post your questions when you are having troubles with your lawn.
post #1 of 7 (permalink) Old 04-07-2013, 06:07 PM Thread Starter
grnspot110's Avatar
Thumbs down Wet Spot Drainage!
Several years ago, before we bought the ground behind us, a new sewer line was buried through the back yard. For those who don't know, these pipes are set in gravel then back-filled with dirt. Our property being on the lower end, water (& yes, other stuff) runs down hill. After we had the ground for a while, a seep started in the back yard about 40' from the property line. The ground water was coming up through a crawdad (Crayfish) hole. I mowed around it for the first year, then dug a trench from the seep to the edge of the grass. I stuck a 1-1/2" PVC pipe into the crawdad hole, elbowed it to a sunken oil drain pan & surrounded the pan with rocks. This runs water in all but the driest conditions.
This Spring, it started seeping again in the yard, so I dug it up today, cut the elbow off the pipe, made a "sump" from a 5 gallon bucket W/lid. Drilled 1/2" holes through the bucket every 4", wrapped the bucket with some old air conditioner filter material to keep the dirt out & slid it over the drain pipe. The "sump" was then surrounded with coarse gravel & buried about 6" under ground.
The previous set-up lasted 5 years+, hopefully this one will last longer! ~~ grnspot
JD; 1953-40 (Standard), 80-314, 93-755 w/60" deck, 2004-790 w/300 loader, 2000-F725 mower, 2007 "TS" Gator and too many attachments to list. , 1980-2418 Power King & 1980-4x8 Snowco Trailer
grnspot110 is offline
post #2 of 7 (permalink) Old 04-07-2013, 09:35 PM
bwdbrn1's Avatar
Seems like that ought to do it. Nice looking solution too.
bwdbrn1 is offline
The Following User Says Thank You to bwdbrn1 For This Useful Post:
grnspot110 (04-08-2013)
post #3 of 7 (permalink) Old 04-07-2013, 10:15 PM
Five Points's Avatar
That's a nice little feature to have a small spring on the property.
Like us on Facebook!
Guaranteed not to Rust, Bust, Collect Dust, Chip, Peel or Leak at the Seal!
I have to go, Frank and Mike are at the gate.....
Five Points is offline
The Following User Says Thank You to Five Points For This Useful Post:
post #4 of 7 (permalink) Old 04-08-2013, 01:44 AM
Founding Administrator
Brad's Avatar
Looks nice as you have it there. A couple of plants or a statue (little boy fishing??) could only enhance it.
Let's work together to make this the BEST lawnmower forum on the web!
Brad
de KA9WRZ
Brad is offline
The Following User Says Thank You to Brad For This Useful Post:
post #5 of 7 (permalink) Old 04-08-2013, 02:11 AM
Mark / Ohio's Avatar
Garage
A bird bath that does not need refilling!
There are several springs around here about a 5-10 minute walk in any direction but none have showed up in the yard yet. At some point I still would like to install an in ground cistern.
Mark - 2002 John Deere LT150H
Mark / Ohio is online now
post #6 of 7 (permalink) Old 04-08-2013, 07:25 AM Thread Starter
grnspot110's Avatar
I gets used for that a lot! And for squirrel & dog waterer. I have a sitting bench & a couple of lawn chairs next to it, makes a good evening shady spot! ~~ grnspot
post #7 of 7 (permalink) Old 04-08-2013, 01:48 PM
motorhead12's Avatar
Looks good!
motorhead12 is offline
The Following User Says Thank You to motorhead12 For This Useful Post:
