Craftsman 18HP B & S Engine technical Carb Linkage Question - Lawn Mower Forums : Lawnmower Reviews, Repair, Pricing and Discussion Forum
New Member Introduction Are you new new to MyLawnMowerForum.com? Please take some time to introduce yourself.
post #1 of 8 (permalink) Old 03-23-2020, 10:30 PM Thread Starter
My older mower has an issue with the throttle not retracting. If I use my throttle cable the mechanisms move and slide and the carb lever throttles up. When I gate down to the turtle on my throttle, everything moves except the lever to the carburetor does not retract. It is not stuck either. Not sure if some spring broke or if there is something on the adjustment side I need to do. Below is a picture of the linkage and carburetor. Any help or suggestions is appreciated. I can manually throttle up and down and the choke works fine.
File Type: jpeg 1A7915C7-5119-4DB9-95C4-00B5E215505F_1585016915925.jpeg (128.4 KB, 5 views)
Bart is offline
post #2 of 8 (permalink) Old 03-23-2020, 10:59 PM
motorhead12's Avatar
When you advance the throttle, do you see the cable opening the throttle plate? Also, engine model numbers really help when looking for missing parts.
motorhead12 is offline
post #3 of 8 (permalink) Old 03-24-2020, 01:40 AM Thread Starter
Pictures of model and direction levers need to retract to when throttled down. Not stuck and all functions, it just doesn’t retract almost like a spring is missing?
File Type: jpeg 309CF438-30ED-4119-862E-D79B254A80BE_1585028313058.jpeg (854.2 KB, 6 views)
File Type: jpeg 9AF1110F-DFE0-4E18-A8CE-773EFFD9F367_1585028334493.jpeg (921.8 KB, 3 views)
Bart is offline
post #4 of 8 (permalink) Old 03-24-2020, 01:45 AM Thread Starter
Here is a schematic of my manual, I don’t know if this helps, I can’t quite make it out.
File Type: jpeg AA8F38C2-2331-4CD4-AFCC-88108226D0CE_1585028712776.jpeg (977.2 KB, 4 views)
Bart is offline
post #5 of 8 (permalink) Old 03-24-2020, 10:43 PM
Typically the throttle cable would directly control the opening and closing of the throttle plate. A spring to the throttle shaft would usually be for the governor to control the maximum speed of the engine. You need to have someone throttle it up and down and watch what the throttle actually does. It's possible that the cable to the throttle just isn't doing its job.
If you could find the model number of the Briggs engine on your mower, which is often on shrouding near a cylinder head or on a tag on the engine, that would help find more detailed diagrams.
post #6 of 8 (permalink) Old 03-25-2020, 09:31 AM
As old as your mower is is it possible something got bent, or something needs lubricated. Sometimes it is the easy things that we forget about.
Joedaddy is offline
post #7 of 8 (permalink) Old 03-26-2020, 03:38 PM Thread Starter
Thanks for the reply, I have cleaned it and everything moves freely, just does not retract, tricky.
Bart is offline
post #8 of 8 (permalink) Old 03-26-2020, 03:41 PM Thread Starter
The cable does control the throttle when throttling up and the cable retracts When throttling down the throttle lever just does not come with it when throttling down, but it is loose and moves freely. Almost like it needs a spring to retract back?
Bart is offline
You may post new threads
You may post replies
