courage 22hp starts hard when hot - Lawn Mower Forums : Lawnmower Reviews, Repair, Pricing and Discussion Forum
 1Likes
  • 1 Post By cranman51
post #1 of 4 (permalink) Old 04-25-2019, 08:30 PM Thread Starter
Hi there
I have a 2007 Toro 50" Courage 22HP lawn tractor with a kohler engine. I'm having trouble starting the engine when hot. It has done this for a long time. When it starts cold, no problem, but after I shut it off and try to restart, the engine turns over slow and sometimes won't start until I let it cool off. The starter was replaced when I got it as it did the same thing I guess.
I wanted to check the valves but I read they were hydraulic.....Is that true?
What else could I check, adjust or replace to make the engine turn over normally when hot?
thanks
Kevcules is offline
post #2 of 4 (permalink) Old 04-26-2019, 08:49 AM
Ericjr16's Avatar
Garage
Yes the valves and hydraulic lifters. I take it it cranks over slowly when hot then? Its normally easier to crank when hot so that's strange?
John Deere LX172 bagger
John Deere 180 yard tug
1997 John Deere 345
1967 Sears Suburban SS10
1971 Bolens 1256
Craftsman 9HP snow blower
Honda HRB215SDA mower
Change is the normal with my tractor list!
John 3:16 Psalm 28:7 1 Corinthians 15:57
"Complain and remain, praise and be raised! "
Ericjr16 is online now
post #3 of 4 (permalink) Old 04-26-2019, 12:43 PM
try adjusting the valves....the compression release won't work if out just a little and when warm might be out more due to expansion?
Kevcules likes this.
cranman51 is online now
The Following User Says Thank You to cranman51 For This Useful Post:
suspicionofignorance (04-30-2019)
post #4 of 4 (permalink) Old 05-17-2019, 03:29 PM Thread Starter
I adjusted the valves as they are not hydraulic, only the heavy duty newer engines have that I was told.
The valves weren't badly out of spec but I adjusted them to .005" (calls for 4-6 thous for each)
The starter drive gear tends to stick up into the flywheek and doesn't always return back to the bottom..
I found I can buy a drive kit but I may need a new starter as mine is now 12 years old. I've got it at Toro right now having the tranny fluid changed. I usually do everything on my own but found out there is something tricky with that. We'll see what Tor says when I get it back.
Kevcules is offline
