Smoking & low RPM - Lawn Mower Forums : Lawnmower Reviews, Repair, Pricing and Discussion Forum
 1Likes
post #1 of 11 (permalink) Old 06-15-2019, 05:09 PM Thread Starter
Angry Smoking & low RPM
My LB 0292-7087, recently started smoking and the RPM dropped after I started it. Never had this issue before? Any clue on what is going on?
DLK
Lawnboyowner!1 is offline
post #2 of 11 (permalink) Old 06-16-2019, 02:30 AM
Yard Nazi's Avatar
Two things to check. First remove the muffler. Tap on it and see if it sounds tinny and hollow. If it makes more of a thud versus the sound of metal the muffler may be clogged with carbon. As a precaution, cook it on a gas or charcoal grill on high for 45 minutes to an hour, let cool, and then shake out all the ash. You can also flush it out with a hose after shaking most of it out. Second, check the exhaust ports. A sign of smoking and low power is a good indication that the engine is not breathing well. Carefully scrape out any carbon buildup, making sure the piston is up so the carbon doesn't go into the cylinder. When reinstalling the muffler, make sure the muffler support, the piece of stamped steel with the three holes, is centered around the crankshaft and not rubbing. Good luck and let us know how you come out. Bill
You will need to remove the blade adapter to remove the muffler. If you have never down this let me know and I will offer some hints.
1968 Lawnboy 3054 Mower
1973 Lawnboy 8231 Mower
1975 Lawnboy 5024 Mower
1975 Lawnboy 5273 Mower
1976 Lawnboy 5274 Mower
1977 Lawnboy 5024 Mower
1980 Lawnboy 7268 Mower
1982 Lawnboy 5247 Mower
1972 Lawnboy 1015 Edger
1987 Lawnboy 1400CL Trimmer
Where there's a will, there's Mr. Bill!
They don't call me MacGyver for nothing!
I have LBAD and DCAD!
Yard Nazi is offline
post #3 of 11 (permalink) Old 06-16-2019, 10:33 AM Thread Starter
Thanks cleaned the ports with dowel rod, did not bake muffler (boss will not let me bake on grille) fired right up good RPM and no smoke. In fall will try cleaning muffler with other method!
keakar likes this.
DLK
post #4 of 11 (permalink) Old 06-16-2019, 08:01 PM
Yard Nazi's Avatar
Talking
Just so you know I have cleaned many mufflers on the gas grill. There is no residue that comes out during baking and no issues with any residual smell after either, otherwise my wife wouldn't approve either. :-)
Bill
post #5 of 11 (permalink) Old 06-17-2019, 03:46 AM
use a piece of tin foil to put muffler on. Then grill away
wh55 is offline
post #6 of 11 (permalink) Old 07-08-2019, 09:11 PM Thread Starter
Well it worked for 3 mows after cleaning ports and muffler, on 4th mow it started fine then RPM's dropped again and started smoking again like crazy. Don't know where to go from here????
DLK
post #7 of 11 (permalink) Old 07-10-2019, 01:15 AM
keakar's Avatar
Quote:
sounds to me like the float needle in the carb is just starting to go bad and randomly flooding enough to smoke but not completely choke the engine.
take the carb loose but dont remove. you just want to separate it from the gasket mount so if it floods it will drip out rather then in the engine. turn key on if you have a shutoff solenoid and see if it starts dripping, if not rap carb bowl with screwdriver handle a few times and then check again waiting about 10 minutes each time. if you see leakage or dripping at all then you know where the problem is, if not you needed to know for sure anyway.
keakar is offline
The Following User Says Thank You to keakar For This Useful Post:
Lawnboyowner!1 (07-11-2019)
post #8 of 11 (permalink) Old 07-14-2019, 01:07 PM Thread Starter
Exclamation 0292-7087 acting weird
My 0292 is acting weird! Ports are clean, muffler is clean & I just cleaned the carb. I installed an line shut off about 6 years ago. Put in new spark plug starts right up after 3 primes runs great for 5 minutes in the driveway, as soon as I hit the grass which was just cut the RPM's drop and it starts smoking, but continues to run slow. If I push down on the handle which lifts the front off the ground it dies and will not start!!!
I am lost.
Any suggestions? Good thing I have my 10424 which runs like new
Thank you.
DLK
DLK
post #9 of 11 (permalink) Old 07-17-2019, 07:46 PM
Yard Nazi's Avatar
Talking
Check the condition of the float to be sure it is nice a shiny and still floating. Could be taking on gas and sinking in the bowl causing the flooding. Simple solution would be to just replace needle, seat and float unless they were recently replaced. Bill
post #10 of 11 (permalink) Old 07-19-2019, 08:10 PM Thread Starter
Smoking and stalling
Well I believe one of the issues with my 0292 is the lower oil seal went bad. Pulled muffle off again after cleaning it about 3 weeks ago and it was soaked with oil inside. So this weekend I plan and tearing it down, replacing the lower oil seal and tearing the carb down also to check float and needle .
Will keep you posted.
DLK
