John Deere z425 - Lawn Mower Forums : Lawnmower Reviews, Repair, Pricing and Discussion Forum
post #1 of 6 (permalink) Old 08-20-2018, 07:29 AM Thread Starter
John Deere z425
I recently got a hand me down z425. This mower was not very well maintained so I'm trying to catch it up on some things. I noticed in the manual that it does not require you to change the hydraulic fluid or filter.
My questions are why wouldnt jd want you to service the hydraulics? Is it going to hurt anything to replace the filter and top the fluid off with fresh fluid? How much can I expect to drain just by removing the filter? What would you do?
The hydraulics are not acting up. This isn't some attempt to save the mower by doing what I'd consider the bare minimum maintenance.
Sent from my SM-G950U using Tapatalk
cmosu is online now
post #2 of 6 (permalink) Old 08-20-2018, 11:35 AM
keakar's Avatar
my thoughts are i cant think of a reason it would hurt to do it
but im not sure if you really put enough hours on it to "require" it to be replaced
keakar is online now
post #3 of 6 (permalink) Old 08-20-2018, 05:07 PM
I'm just guessing as I haven't looked at them in a while. I think the Z425 is is considered "pro-sumer" grade and has a lot of features, but still has sealed trans. Like no drain plugs, internal filters, zero maintenance type thing. You'd have to look up the specs or crawl under and look up the tag number on the trans. I think some came with what JD called an expansion tank that we would call a reservoir so there is an access point, but you may have to remove the trans and tip them upside down to drain My guess would be the Tuff Torq TZT , Deere may have had some with Hydro Gear, but I've never seen a Z-turn Deere with one.
If it does have the filter (plastic holder kind you set a ratchet head in to remove) , I'd definitely replace it. If it's the only drain source you won't get all the fluid out. I have a very old LX188 that has a K61 TT trans and it has 2 drain plugs to drop the the pump and dif fluids, but it does not have an external access filter. Our X530 has the K72 which has 2 drains and an external filter access.
jtclays is offline
post #4 of 6 (permalink) Old 08-20-2018, 05:42 PM Thread Starter
Im pretty sure it is a Tuff Torq. The only filter I've seen is a single spin off filter mounted under the frame below the reservoir. Aside from the filter I do not remember seeing any drain plugs.
cmosu is online now
post #5 of 6 (permalink) Old 08-20-2018, 08:26 PM
I just looked up Z425 on JD parts and they list both Hydro Gear and TT depending on serial numbers. HG's look to have a filter on each side and the TT none on the trans, but looks like they had a central pump with one?????
John Deere - Parts Catalog
jtclays is offline
post #6 of 6 (permalink) Old 08-20-2018, 08:41 PM Thread Starter
That is correct. Mine is an early model with the TT. Single filter under the reservoir on the left hand side.
cmosu is online now
