Steering issues - Lawn Mower Forums : Lawnmower Reviews, Repair, Pricing and Discussion Forum
 1Likes
  • 1 Post By keakar
post #1 of 5 (permalink) Old 05-13-2020, 12:25 PM Thread Starter
Steering issues
I have a Husqvarna LGT24K54 mower. The front tires are wearing funny and the caster and camber are both way off. one tire is straight and the other is cockeyed and they both tilt in. is this normal or should they be straight both ways. And what could be the cause of this is it the spindles or drag links? Is there a way to correct this or what parts may need replacing?
bigzeik is offline
post #2 of 5 (permalink) Old 05-13-2020, 01:26 PM
stumpy622's Avatar
If the wheel wobbles on the axle, the bushings are probably worn out. My experience is the factory bushings on those tractors are pretty cheap. Packing them full of grease is a temporary solution, but might get you through the day. Replace the bushings with bearings, like these, should solve your problem and last much longer:
Just make sure your wheel is 1-3/8" and a 3/4" axle. Good luck!
Montani Semper Liberi
stumpy622 is offline
The Following User Says Thank You to stumpy622 For This Useful Post:
bigzeik (05-20-2020)
post #3 of 5 (permalink) Old 05-13-2020, 01:49 PM
keakar's Avatar
Quote:
bushings in the wheels are bad and need replacing
also check the spindle shaft at the bottom, if you see a notch or groove then they need replacing
taryl explains it here
im not sure about his solution personally, i think i would replace the spindle arm and new bushings for the wheels to go back oem setup unless those bearing things he used are just as cheap to buy
one day when you are bored go watch a bunch of his videos, he makes you laugh and teaches you just about everything on anything lawn mower related you might have questions about
Grunt likes this.
keakar is online now
The Following User Says Thank You to keakar For This Useful Post:
post #4 of 5 (permalink) Old 05-13-2020, 06:26 PM
penna stogey's Avatar
Garage
First post needs a hearty welcome...Hearty Welcome from Gettysburg address
Perpetual Optimism is a force multiplier!!
John Deere D-140
Toro 22" GTS, 6.5 hp SP Personal Pace
97 Lawn Boy 10200, 6.0 hp
Troy Bilt 21" TB230 4 .5 hp, SP
penna stogey is online now
The Following User Says Thank You to penna stogey For This Useful Post:
post #5 of 5 (permalink) Old 05-20-2020, 09:59 AM Thread Starter
Its not the bushing in the wheels. Is it possible that the spindles were for the wrong sides, or the drag links are not correct?
bigzeik is offline
