Thanks for posting these links
twocycle. This thread is almost 2 years old and I wouldn't have seen it otherwise. It appears that the OP has a Tecumseh with the primer bulb built into the carb. I have an old snowblower with a 5 hp Tecumseh and it's very frustrating to start after it hasn't run for a while. It has a remote primer bulb without a vent that connects to the float bowl. Near as I can figure out, it just blows air into the float bowl in an attempt to jiggle the float and cause a little bit of flooding. I've checked the bulb and connecting hose and there are no leaks, but even 100 pumps of the bulb have little effect. It's faster just to remove the plug and pour a slug of gas or a shot of ether into the cylinder.
Reading from the Tecumseh Technicians Handbook linked above:
Quote:
Two different methods are used to prime float style
carburetors, leg prime and bowl prime. The leg prime
system is used only on the dual system carburetor. Air is
forced into the center leg of the carburetor, which then
forces an enriched mixture of fuel up the main nozzle. The
bowl prime method is used on Series 6, 8, 9 and 10
carburetors and is distinguished by a stepped or hour glass
shaped primer bulb. A good seal of the primer bulbs center
lip is critical to assure that a full charge of air reaches the
bowl. Also critical is a tight seal around the float bowl.
... the only thing I can think of is leaky float bowl gasket. Opinions?
