1995 Jon Deere sabre - Lawn Mower Forums : Lawnmower Reviews, Repair, Pricing and Discussion Forum
Old 04-28-2012, 02:55 PM   #1 (permalink)
Default 1995 Jon Deere sabre
I have a 13 hp Briggs on a 1995 John Deere Sabre that will only run with the choke closed. I overhauled the carb and changed the intake valve with a new Briggs valve. It still pops through the carb and will not run with out choke closed. Please help.
Damato is offline   Reply With Quote
Old 04-28-2012, 11:05 PM   #2 (permalink)
Default
popping or spitting back through carb. is usually an indication of intake valve not fully closing during exaust stroke or a partually sheared woodrift key on flywheel.
fixer is online now   Reply With Quote
Old 04-29-2012, 09:27 AM   #3 (permalink)
Default
I have put in a new key and lapped and set the proper clearence on a new exhaust valve. Seems like the motor has a lot of blowby with compression at 60 PSI.
Powered by vBadvanced CMPS v3.2.2
Powered by vBulletin® Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.6.0
