15hp kohler in yardman rider isn't getting spark - Lawn Mower Forums : Lawnmower Reviews, Repair, Pricing and Discussion Forum
post #1 of 3 (permalink) Old 10-12-2011, 06:57 PM Thread Starter
15 hp kohler isn't getting fuel or spark. any ideas?
chaseschrimsher is offline
post #2 of 3 (permalink) Old 10-12-2011, 07:06 PM
Austen's Avatar
Welcome to MLMF!
For starters, what model is your Kohler?
When it comes to fuel, it could be a number of possibilities. I'd check the fuel filter first to make sure it's not clogged and that its getting fuel through it. It's been known to happen. If it's ok, I would venture to the carb as it probably has an obstruction somewhere in it. To clean it, you can pull it apart and soak it or blow compressed air through the ports. If it is later unit and has a fuel pump, the problem could lie somewhere related to that like a faulty/corroted connection somewhere.
Spark wise if it has a points and condenser type igntion, I'd clean and check the point gap. If a no go, I'd venture onto the condenser. If the ignition is electronic I'd probably have the ignition coil tested and check all the connections to make sure they are clean.
Here are some links to visit:
http://www.kohlerengines.com/mainten...leshooting.htm
http://www.kohlerengines.com/manuals/landing.htm
Austen is online now
post #3 of 3 (permalink) Old 10-12-2011, 07:06 PM
Founding Administrator
Brad's Avatar
Greetings, and welcome to the forum.
What's the setup for the fuel? How do you know it isn't reaching the engine? Plugged cap? What type of machine?
Let's work together to make this the BEST lawnmower forum on the web!
Brad
de KA9WRZ
Brad is offline
Human Verification
