John Deere STX38 Won't Start - Lawn Mower Forums : Lawnmower Reviews, Repair, Pricing and Discussion Forum
post #1 of 12 (permalink) Old 10-05-2011, 09:06 PM Thread Starter
Exclamation John Deere STX38 Won't Start
Hi Folks, I've been trying to get my John Deere STX 38 started. It has a Kohler 13 Command Engine and Hydro transmission. It turns over but won't start. There is no spark. I've checked out all of the circuits with a multi-meter, all fine. I have jumped the seat and brake pedal safety switches. I thought the iginition switch was the problem, replaced that today, still won't start. Now I have the engine cover off, there is continuity all the way from the ignition to the wire at the magneto. No voltage on this wire when the key is on. Ran the coninuity meter from the magneto lead to the spark plug wire, none. Do these magneto coils ever fail? What else could lead to no spark? Thanks for your input.
markbus@comcast.net is offline
post #2 of 12 (permalink) Old 10-05-2011, 10:40 PM
Mark / Ohio's Avatar
Welcome to the forum Mark. Yes coils do fail and since it sounds like you checked things over pretty good I would say it is likely the problem. I'm guessing your engine is probably a CV-13. Here's the manual if you do not already have it from Kohler's website:
http://www.kohlerengines.com/onlinec.../tp_2339_d.pdf
Page 61 & 62 explains how the electronic ignition system works and troubleshooting procedure for the coil on that model. The electronics and the coil are combined together in one part. Makes the odds even better that is your problem.
Mark - 2002 John Deere LT150H
Mark / Ohio is online now
post #3 of 12 (permalink) Old 10-05-2011, 11:53 PM Thread Starter
Hi thanks for the advice and the Kohler manual. I'll check that out.
post #4 of 12 (permalink) Old 10-06-2011, 11:34 PM Thread Starter
Bad news, I replaced the magneto, and even the spark plug in case it was defective, and still no spark. At wits end here, what else could it be? Something grounding out the white wire to the magneto?
post #5 of 12 (permalink) Old 10-07-2011, 01:48 AM
Dang! It could still be a short on that kill wire someplace. You could try measuring resistance to chassis ground on it. If reads a short then work backwards from there. Maybe a wire rubbed bare someplace against the frame.
Have you removed the jumpers you placed on the safetys for testing? Depending on the configuration sometimes those switches or normally open rather then normally closed.
post #6 of 12 (permalink) Old 10-10-2011, 03:48 PM
BOSMECH's Avatar
Is there a nuetral switch on it ?
Did you also try removing all the safety switchs from the circut ? (running it hot)
Also check to see if the coil ground wire is shorted out to ground.
Just some thoughts that I would check first.
BOSMECH is offline
post #7 of 12 (permalink) Old 10-11-2011, 11:45 PM Thread Starter
Hi Mark and Bosmech, thanks for the reply. Sorry for the delayed response, I was away for the long weekend. I unplugged the junction wire to the regulator (that recharges the battery) and the white kill wire to the magneto, and presto, I had spark. I've plugged those back in and no spark again. So I think you are correct that it may be a short somewhere in the kill wire. I have checked and don't see any frayed wires grounding out anywhere. In terms of the safety switches, yes they are still jumped - one jumper in the seat switch, and 2 in the brake pedal switch. I'm not sure if any are supposed to be normal open, but I did have continuity from the white wire on the magneto all the way back to the ignition switch with the jumpers in place. I'll try your suggestion of working backwards checking resistance in the wire for a short, and the neutral safety. Need to figure this bugger out, as the grass is getting longer!
post #8 of 12 (permalink) Old 10-12-2011, 10:09 PM Thread Starter
Further update - unplugged the white jumper wire in the brake switch, and left the purple one in for the starter circuit. The good news is it now starts and runs, and moves; although brake and seat switches are currently bypassed. Bad news is when I turn on the PTO switch to engage the blades, the motor stalls out. Could that be a ground problem or low voltage?
post #9 of 12 (permalink) Old 10-13-2011, 12:05 AM
My guess would still be with one of the switches grounding, shorted, or open. I found a couple STX38 wiring diagrams on the net. You'll need to check your serial number to see which diagram applies.
post #10 of 12 (permalink) Old 10-13-2011, 10:50 PM Thread Starter
Hi thanks for the wiring diagram. Mine is the newer one (bottom diagram) with no neutral safety. I charged the battery and then checked the voltage to the PTO itself, she's getting 12 volts. With the key on and the engine not running, I pulled up the PTO and it clicks at the PTO which means the solonoid is engaging the PTO. I removed the belt on the PTO to the mower deck (to remove resistance and vibration), started the engine, pulled up the PTO switch, and the engine died just like turning off the key. So I think you are right, a short or ground out somewhere. In fact, the same short that was preventing the engine from starting before is most likely also causing the engine to stop when I engage the PTO. From the diagram it is probably somewhere in the black/white wiring, or maybe the PTO switch itself? The wiring goes into the frame so I cant see whether it is touching somewhere inside. I have a meter but not sure how to check it for shorts to ground - 0 ohms? How many ohms for normal?
Human Verification
  LinkBacks (?)
LinkBack to this Thread: http://www.mylawnmowerforum.com/forum/18-john-deere/1311-john-deere-stx38-wont-start.html
Posted By For Type Date
John Deere Stx38 Wiring Diagram - starter assist relay assembly and install mytractorforumcom This thread Refback 08-29-2016 07:37 PM
john deere stx38 starter problems This thread Refback 06-30-2015 05:29 PM
John Deere STX38 - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information This thread Refback 05-30-2015 01:41 PM
John Deere STX38 - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information This thread Refback 05-22-2014 01:15 PM
John Deere STX38 - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information This thread Refback 06-17-2013 11:59 PM
John Deere STX38 - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information This thread Refback 06-14-2013 05:27 PM
John Deere STX38 - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information This thread Refback 06-02-2013 12:30 PM
John Deere STX38 - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information This thread Refback 06-02-2013 10:37 AM
